was doing some work on the car tonight,
replace the stereo head unit
remove greddy boost guage
cut wire for greddy brain for the P.H.W.
basically it,but now it wont start, thinking i might have disconnected some wire or something. I have a Map Ecu 1 and oem auto tt ecu. checked the EFI fuse one and two under the hood. when trying to start the car it will inguage the start but wont start, just keep trying to crank. dont have an aftermarket FPR so i cant check that but i have half a tank and the car started an hour before.
can someone swing by to check the wiring that knows more then i do? willing to pay if you can figure it out.
call my cell at 520-247-8227
thanks! Tony
ok so i go out this morning and check the wiring in the dash again, try to start it now nothing at all!!!!!
no crank or nothing, all the dash lights up, etc... but no crank like last night..im stumped... check the EFI fused, all fuse under hood and driver side kick panel and they all seem good. this car has a wiring mess and i try to trace each wire and there are some idsconnected but it seems to be for the turbo timer but can find where the other ends go, but i remember them being disconnected anyways before i started the work. plus didnt touch anything under the dash when i was working on it last night, until after it wouldnt start, trying to figure out what is going on. the MAP ECU 1 light up one red led, are they both surpose to light up?
thanks! Tony
