The car will crank but will not start.
History:
Did a single upgrade on car. Before upgrade car was starting fine. Did have a weak battery but I have a charge I used to bypass the problem. During the swap I replaced the timing belt and the front main seal. I added some gold gasket sealer around the seal to help prvent leaks. During the install I notice I broke the connector for the CPS sensor. Ordered and replaced
I've reviewed the forums I have checked and/or replaced the following in an attempt to resolve the issue:
Crank positioning sensor
ignitor
ECU
Checked all fuses, check CPS signal back to ECU (B7,B27) and there is a fluix when the car's cranked. Check fuel pressure and that the fuel pump is working (removed fuel line into filter and jumpered B+ and FP on DLC). When the key is turned to the on position the amouint of fuel dripping increases significantly. I can also feel the stream on the other side of the filter in the line to the fuel rail. I checked whether the timing belt was slipping. It does appear to be. Check the vacuum line to the FPR and it's connected. I can't see how this would prevent the car from starting but some suggested in one of the posts. I pulled all fuses and double checked. Check the IGN fuses in the kick panle on the drivers side.
Guys I'm stumped. ANY HELP would be greatly appreciated.
History:
ignitor
ECU
