1 - 2 of 2 Posts
I had alot of carbon on #6, so much that the valves would not close. There was also some on #5 and #4 (not as bad), and alittle bit on hte other valves.
I read the threads on EGR valve and EGR cooler. The EGR valve is bad and gets stuck when we mess with it. The mechanics thinks I should remove the EGR valve and plug the cooler, which should allevaite the problem.
I can't find an aluminum plug, I found some alumiuim bolts, does anyone know a good length to use? I was going to use 3/8 16, 1/2'. Thanks for the help
I Didn't Do It!
Just purchase the blockoff plates? or did you already do it. I'm not exactly sure how it's done as i've yet to do it. Good luck
1 - 2 of 2 Posts
