1 - 18 of 18 Posts
Broke Supra Addicted Fool
Heres some pics of what happened after my wastegate hose melted through.
Its hard to see cause the pictures aint the best but the whole exhaust side of the #5 piston melted away and partialy deposited itself on the cylinder wall (the gray blur on the cylinder wall).
Does anybody know where I can get a set of pistons & rings to rebuild without waiting 10 weeks?
When things like this happen I think it is best if you get a good used short block to rebuild. There could be other things that are damage in your block that you can not see with your eyes.
^ yeah I would find another short block, I know your current one was built but you may half to cut your loss and get your car back on the road if your in a hurry...
I'll nevAr go single!
Hmm, whats this Wastegate line look like, and where is it?
Wanna make sure mine aint to close to the turbos or somethin.........
Stupid question, I know..
It's the vacuum line that goes from the wastegate actuator to the compressor housing.
You can see the vacuum lines in this picture.
You shouldn’t have to worry about them melting if you are on stock twins though.
Awsome, thanks. Ya, stock twins.
Not so boring anymore
i need to rerun my wg line... ist running right near my dp.. every once in a while its resting on it.. im lazy though.. maybe i wont be so lazy... well i got boost cut at 18 psi.. so maybe i will.. lol
Now with 0JZ
heh, I had a WG line ment through once. It was that shitty clear tubing you get at any auto parts store. Couldn't figure out why I kept hitting boost cut :p
Discussion Starter · #12 ·
Unfortunately my car has an fcon v which gets rid of boost cut...
well just to answer the original question: any 2jzgte pitons and ring will fit, so you wont need to wait 10 weeks for those.
glad my haltech has a overboost cut I can setup :)
Looks painful, luckily 1jz shortblocks are cheap and seem fairly plentiful.
Discussion Starter · #18 ·
Yeah found out about the 2jz pistons recently but a local place had a good jdm import 1jz longblock that I scooped up and am tearing down and bolting my shiz onto, should be up again in a few days and ill snap some new pics of the car... added a bit of my own taste to it.
1 - 18 of 18 Posts
