The supra that I have has had the carpet in and out of it, and it doesn't sit exactly snug against the footwell/ center very well. And with a 90 MM TB, sometimes the pedal gets stuck on the very edge ( the tiny lip ) where the hard vinyl is molded into the carpet, so I cannot feather the pedal some times, and I put more and more pressure on it, until it lets go, and the car revs to 3500 rpm :} With the clutch being the biggest B#### I ever had the pleasure of driving, I cannot start or slow the car down without having it buck all over the place.
Should I try putting a little bit of glue behind it? What kind of glue should I use? Something not SO strong Id enver be able to remove the carpet without tearing the crap out of stuff, but not too soft so it keep pulling loose? Any thoughts?
