Well since cassio has been banned from the likes of SF here
is a little update of his progress that can be seen on a certain other supra site :sadance:
Copy/paste from said maniacle site:
6/18/06
Well Just wrapped up a fun-filled two days.
Currently have the engine on the stand to assemble the rest of the engine
before it is re-inserted into the engine bay.
The recipient:
The engine (* DO NOT BUY A VECCO Manifold!!!!)
had to drill out all of the stud holes, and grind down one stud.
Also had to chop off the wastegate tube :icon_evil
Custom pre 89 mounts:
A nice "dirty" test fit:
So far took everything back out and reassymbling the engine on the stand.
Pressurewashed and detailed bay.
Fabbing up custom lines for the hydro fan and misc other things.
Next:
Turbo installation (oil feed, return, exhaust, WG plumbing)
Redo IC pipes from my 7M FFI pipes
Redo Brake system
Install new rear subframe
Wiring
Should be done within the next 2 weeks (x my fingers)
-ian
Round 2
6/22/06
minor update,
Well as many people that do this swap change the fron x-member. I went with one-off custom brackets and decided to change my rear x-member (subframe)
My old 87 sub frame was cracked and i found a mint 89 frame to replace it with. Also decided to replace teh fuel filter again
gtfo!
re-installed thanks bryant! no idea we would damn near die.... finished later than we wanted to... on a school night too!
Dropping engine back in this friday to check some clearances, then saturday going for final mockup and install...
wiring to start Monday!!!
6/18/06
The recipient:
Next:
Redo Brake system
Wiring
-ian
Round 2
6/22/06
minor update,
gtfo!
