1 - 19 of 19 Posts
· Trev
I got a set of ccw 505a's. They are 10x19f and 11.5x19r and the fenders have been rolled. Tires are 265/30 and 305/30's. Now, I have coilovers installed on the car, but haven't dialed them in yet, so with the wheels/tires installed, there is still about a 4" gap between the fender lip and the top of the tire...now, when I look straight down at the front wheels, they are appearing to stick just a little farther out past the fender...it worries me a little as I really was hoping CCW would have made them with the perfect offset to be flush with the fender as it is in the rear...is this because I need to lower the car and adjust the camber?
Trev
I have the same setup as the white car above. 285/30/18's and 315/35/17's, slammed on Teins. No front rolling is required. There is a bolt in the top of the fender that holds the liner in place that you'll need to remove... or hit enough bumps while lowered and it will be removed for you. Whatever you prefer. :D
I know the classics aren't the wheels in question here, but the offsets are similar and should provide reference points.
· Trev
Discussion Starter · #15 · (Edited)
If you knew anything about suspension geometry, you would have answered your own question.
Very ignorant statement. Typical response from someone that doesn't take the time to think about what they say before saying it. Take a simple lesson in human relations and realize that people can only be held accountable for what they know. I'm sure if I asked a question in calculus, by your reasoning, you would chastise me for not knowing the answer and that if I had known calculus, I could have answered my own question.
wow, really? awesome, so lets just copy and paste that response and stick it to every single question on the board shall we? what was the point of this reply?
someone asks about a turbo you can reply
"if you knew anything about turbochargers, you would have answered your own question"
someone asks about a wire hanging somewhere in the engine bay and has no clue where it goes
"if you knew anything about the supras wiring, you would have answered your own question".
i thought mods were held to a higher standard than the rest?
saw trevs car today, looks awesome on those ccws, and the new HID's fit well after a little fixin lol.
· Trev
Discussion Starter · #18 ·
Thanks again for the help!
1 - 19 of 19 Posts
