1 - 20 of 29 Posts
Brevity is our fortune...
1. Looking to refresh my parking brake, it's lost its grip. What do I need to rebuild it?
2. Looking to replace my interior center rear view mirror and mount.
thank you
Anime Dork
46201-14270-c0 lever sub list 150.67 cost 113.00
87810-14180-c0 mirror as list 113.18 cost 84.88
87817-24010 spacer, i list 6.26 cost 4.69
87808-24010 holder su list 2.27 cost 1.70
87825-24010 spring, i list 1.24 cost 0.93
this base for the mirror is discontinued. All other parts for the mirror are available.
by base are you referring to the metal post mount that glues to the windshield?
I apologize on the parking brake, I should have been clearer. My interior handle is fine, looking to refresh the brake shoe/wear items themselves that hold the car.
thank you
Anime Dork
I'm referring to the base that the mirror connects too.
46540-44010 shoe assy list 34.59 cost 25.94 x2
46550-44010 shoe assy list 34.59 cost 25.94
46590-44010 shoe assy list 34.59 cost 25.94
47447-50010 pin, shoe list 1.95 cost 1.46 x2
47447-30020 pin, shoe list 1.95 cost 1.46 x2
90506-12051 spring, t list 2.90 cost 2.17 x2
47405-30040 screw set list 61.20 cost 45.90 x2
47406-30040 screw set list 61.20 cost 45.90 x2
47449-30030 cup, shoe list 2.13 cost 1.60 x2
47449-40010 cup, shoe list 3.07 cost 2.30 x2
90501-16053 spring, c list 2.04 cost 1.53 x2
90501-16118 spring, c list 1.35 cost 1.01 x2
90905-a6001 spring, t list 4.48 3.36 x2
47459-30010 bolt, sho list 5.37 4.03 x2
47456-33010 plate, sh list 2.10 1.57 x2
90504-14002 spring, c list 5.66 4.24 x2
Thank you, may add a couple other items.
plastic stock dead pedal assembly still available?
Plastic hook that holds front drivers floor mat ?
Senior Member
Any luck?
What i found with a quick google search of curts old thread:
The clips snap into a black plastic retainer in the carpet .
58297-50020 RETAINER, LIST 5.26 COST 3.94 EA
08211-00720 STEP 2 MATS CLIPS LIST 3.95 COST 3.00 [ PER PAIR ]
Anime Dork
58297-50020 retainer, list 5.55 cost 4.16
08210-00820 clip, flo free
now i know the reason i couldn't find these part numbers. They are not listed for the supra at all but are simple replacement parts.
Discussion Starter #11
sweet thanks all, is there an order number I should reference when I call for the clips, parking brake mechanical refresh items, and the mirror pieces?
Discussion Starter #13
Actually couple other items:
Gaskets under exterior door handles (both sides)
interior Plastic steering covering steering column
Anime Dork
Those gaskets come with the door handles and are not sold separately also they are discontinued.
Are you looking for the upper or lower cover on the steering column?
Discussion Starter #15
Working on the column have to check mine closely.
Couple others -
Rear Hatch plastics:
64740B LH Deck trim
64730C RH Deck trim
Discussion Starter #17
Actually just need all the stock screws for it, can I still get those?
Discussion Starter #19
1 - 20 of 29 Posts
