what brand are you guys using? should i get ceramic or half mettalic? also what brand?
thanks
atif......
thanks
atif......
is that what toyota sells or is it something different?hawk pads
no , they are made by hawk ....ill be going with those pads when i change my brakes ....lol even though i suggested the stock pads .....hawks can sometimes be noisey from what ive heard , but i dont careis that what toyota sells or is it something different?
If you don't track your car on roadcourses, IMO the stock pads are best. Otherwise, the right answer must be location dependent since apparently in ZOO YORK ceramic pads are junk.to my understanding and from what ive seen , the ceramic pads will warp the rotor faster because they will hold on to heat longer ....ceramics are ment to be quiet , not for performance ....in my opinion , they are junk ....go with the stock toyota pads
Hawks are made by Brembo, I believe.no , they are made by hawk ....ill be going with those pads when i change my brakes ....lol even though i suggested the stock pads .....hawks can sometimes be noisey from what ive heard , but i dont care
yes i believe you are right about the brembo thing ....i ment to say that they were sold under the name hawk ......Hawks are made by Brembo, I believe.
I just switched to Hawks and have not had any noise or dust problems.
I am going to track the car Sunday at Road Atlanta, so I'll see how they do there.
im just telling you what i have noticed from working on all types of cars ....maybee a high performance pad like the ones you use are good out in SEPA but the commonly sold , day to day , available anywhere brake pads that ive seen are a waste of money ....as well as on my own cars i have tried them and wasnt impressed .....i got 40,000 miles out of a factory honda rotor with the factory organic pads (changing them at 20,000 miles and needing them @40k) ever since then , with a ceramic pad , the rotors were shot and pads were worn in 15k (thats with the better choice aftermarket rotor ) and the semi met. with new cheapo rotors actually lasted longer on my gf car than the ceramics with the better rotors as i had tried both .....thats all im sayin ....and out here in ZOO YORK we dont have the luxury of highway driving all over the place like you guys in SEPA :1poke: ...theres a traffic light every 15 feetIf you don't track your car on roadcourses, IMO the stock pads are best. Otherwise, the right answer must be location dependent since apparently in ZOO YORK ceramic pads are junk.
Most other places they can perform very well. Last pad set I had and I just got a new set were Carbotech XP10's which are ceramic. I'm pretty sure all the Carbotech pads are ceramic. Sometimes I track my car so the stock pads are totally useless for repeated hard braking on a roadcourse. OTOH, the Carbotech's are simply awesome. The XP10's work great on the track, still have quite good initial bite when cold on the street, not much dust though not low dust by any means, and no noise. http://www.ctbrakes.com/overview.html If you don't brake hard on the track, I'd suggest dropping down a grade or two, like the XP8's or the next one down.
PS: never warped a rotor with Carbotech's either, though I'm half embarrassed to admit that I don't brake hard enough to warp rotors![]()
well if they PREVENT LESS DUST , wouldnt the make MORE DUST ? :rofl: lol just brakin balls ....I've used Hawks for the past 3 years on all my vehicles.
Well according to tirerack, ceramic pads are quieter and prevent less dust.
On a side note, for a GS400 it is recommended that you run nothing but ceramic for some reason...
Hawk HPS for me.when you guys are referring to hawks do you mean hawk hps, or hawk blue pads?
some times the brakes feel like when you install the a brand new pads and press the padel after the first time installing it and when you press it again it started working. so thats what it feels like. but not all the time probably like once in say 60 miles.Seriously ask yourself: have you ever faded your stock brakes?
If not, just stick with them. If you start doing multiple braking cycles from high speed, or many braking cycles driving fast down winding roads and you notice fading, then you are overheating your pads and should consider stepping up to a more fade resistant/aggressive pad with stock rotors. Above that level are still more aggressive pads and then the better big brake kits.
