Did you first release pressure on the anti-rattle clip? If not, that's probably your problem. You release the pressure by pressing on one side of the clip(one is easier than the other) while pulling on the pin (on the same side).sleeper said:Tried lightly tapping the pins, sprayed the heads and opposite end with WD-40 for an hour still no luck. They are stuck pretty good. My last resort is a dremel or drill those b$st#rds out.![]()
