·I am in the middle of changing my spark plugs now and I have a couple questions:
1)There are 2 vaccume hoses that connect to either side of the valve cover. They seem very hard and brittle, and I'm scared they are going to break if I try to forcefully remove them. Are they supposed to be this way, or should I get some new hose? Will any automotive hose do, or should I get them from Toyota?
2)Also I picked up a set of NGK 3330's. What size are they pre-gapped? I wanted the 6097's, but couldnt find them anywhere. I was told they are the same plug, but are just pre-gapped at a different size. What size do you recommend for BPU? I was told .031, or .032. Does that sound right?
Thanks alot.
-Steve
Thanks alot.
-Steve
