If you're stock then the stock plugs should be fine. Once you get to BPU then I'd go to 3330's and keep the gap they come with. Some ppl have also had good results w/ NGK 6097's.New Owner said:
Good luck.
Scott
If you're stock then the stock plugs should be fine. Once you get to BPU then I'd go to 3330's and keep the gap they come with. Some ppl have also had good results w/ NGK 6097's.New Owner said:I'm changing out the sparkplugs in my totally stock Supra TT. What is a good brand to go with and what gapping should I use. Someone told me to go with the NGK 3330's. Are these good for a stock supra TT with stock boost?
