1 - 12 of 12 Posts
Eversince i installed the AFPR on my car, my charging system is only working @ 12.8 - 13.2v
I couldn't tell what the hell is going on.
Story:
While installing the AFPR, i forgot to disconnect the battery and the wrench touched the alternator positive terminal to the car's body. Sparks flew and i quickly remove the wrench.
As far as i could tell, that fucked up my door auto door lock (locking the driver & passenger door by the master lock switch on driver's door). What's even weirder is that, i can auto lock & unlock my car as long as the car is running. Once the car shut off, i can't do shit. I have to manually lock both doors.
Anyway, back to topic.
Once the AFPR got installed & running. I noticed that my turbo timer reported my charging system is only @ 12.8-13.2v
At first, i thought it's my alternator going bad so i replaced it with a brand new one from autozone. I even went as far as replacing it with a higher output alternator (100amp mr-2 turbo vs. 80amp stock) and still no luck. it's still charging @ only 12.8-13.2v
Does anyone have any clue? Is it my AFPR or is it because the wrench made contact with the alternator that fucked everything up?
Only 12.8 - 13.2? What do you think it's supposed to be at? Mine always ran around there. It might drop if I was using a lot of my power draining accessories, but it was almost always in that range. What did yours used to be?
As far as the door locks go, I'm not sure. I never had them work when the car was on and not when it was off. Maybe someone else can shed some light there.
boost freak
"normal" vehicle charging systems should run @ 13.8-14.5V above 1k RPM or so.
based on what happened, i'd guess you killed your battery- too much current delivered damaged one of the cells or something. measure your batt V w/the car off. i'd guess it's sub 12V.
Mine used to be 14v
Got Boost?
This is exactly correct. I run AVR tests on cars daily and this is what a healthy charging system is at. I dont think you killed your battery because in that case it would be charging heavily. Have you solved your problem yet or is this still a concern? Id be tempted the check the alternator fuse.
how could it be healthy when the car was working @ 14 volts before?
now it can barely stay running if i have the heater on, rear defroster, lights, and head unit.
wtf.
Mine sits at 14.4 at idle with accessories off. when i turn the head lights on and defroster with stereo on it drops down to 12.8. at idle and when driving goes back to around 14.2
N/M i found the culprit of it! The alternator fuse is blown. :) stupid of me. i shoulda check that first.
Could anyone tell me how to take the fuse off? i've tried pulling it and it's stuck on the damn thing like superglue. I tried using a pliers and it still wouldn't come out. all it does it break the damn fuse even more.
make that blkGT4294 LOL!
Unscrew it. It's screwed in from the bottom. BTDT!
-Nick
Got Boost?
Kroze, im glad you found your problem. When i said "this is correct" i was referring to Dr.Jonez post about that its supposed to be about 14.5 volts if its charging correctly. Thats why i told you to check your alternator fuse. But i see you found that that was the problem anyways :)
1 - 12 of 12 Posts
