I thought I had seen that somewhere...thanks for pointing it out!You do realize mvpmotorsports sells the DME one for the same price.
*EDIT* Actually 4 dollars cheaper.
any reason you are saying that having an extra piece to direct air flow is bad? because factual data has proven to help with cooling by adding a plate to help direct air through the radiator and not above it.I wouldn't.. There is a reason that Toyota didn't put some plastic there to duct the air. I'm guessing engine bay temp or maybe some preassue zone thing.
Maybe you need to read the forum rules about posting "Fleabay" links as your not a newbie. :gtfoslap:Anyone bought one of these? Quite a bit less than all others out there...
http://cgi.ebay.com/ebaymotors/Toyo...rQ5fTruckQ5fPartsQ5fAccessories#ht_500wt_1182
Youre right, my bad. Fixed. Bought at MVP.Maybe you need to read the forum rules about posting "Fleabay" links as your not a newbie. :gtfoslap:
Bingo!Yeah it's called getting a good deal and supporting the forum vendors.![]()
Toyota also didn't put a giant FMIC completely blocking off direct air flow to the radiator and condensor. This helps direct air back that the FMIC took away.I wouldn't.. There is a reason that Toyota didn't put some plastic there to duct the air. I'm guessing engine bay temp or maybe some preassue zone thing.
Irony.Maybe you need to read the forum rules about posting "Fleabay" links as your not a newbie. :gtfoslap:
Um yes they did. There is a plastic duct that runs from the top of the bumper mouth to the top of the rad support. I am stripping my 94 tt and the plastic piece is still there. When you go Front Mount you need to remove the plastic piece, therefore it is smart finding another way to direct air into the rad/front mount.I wouldn't.. There is a reason that Toyota didn't put some plastic there to duct the air. I'm guessing engine bay temp or maybe some preassue zone thing.
