I own a shop, I give people a choice, do you want it to look factory, better than factory, show quality? or do you want it to shine for the next few years? you got single stage paint jobs, macco, then you have bace coat/clear coat paint jobs, factory. another thing you have to take in consideration, like superstar stated, do you want the glass pulled, door handles, side mirrors, bumpers, side skirts, headlight/taillights, etc.? All this starts adding up, BUT, that is the best way to have it done. If you want the best job you can have, you need everything taken off the car. I like PPG myself, they have a cheaper line they sell called OMNI Plus. You can use it for all-overs. Then you have a good clear put over it, there again, you usually put no more than three coats of clear. If you want more than that, the shop will need to let it cure for at least a week, then they will need to sand it back down and reclear it. then if you want all the orange peel taken out, they would need to cut and buff the whole car. The TV shows really make it look easy, but what you do not see is the hord of people helping to get that car to the point where one guy is standing by it painting it. They dont usually show it getting sanded and buffed so that it looks like glass when you look at it.
Supra469,
I am personally gonna put 3 different coats of clear on my car. What I mean by that is, I will put three coats of clear on it, let it cure, then repeat that process two more times or untill I have the look I want.
As far as primers go, most primers are ok, you mainly want a urathane primer.
Metallics are what you usually see and a car that is not a soild color, usually if it has a shimer to it, its a metallic. Pearls are what you see on white caddys most s the time and some nissans. looks like the shimer is actually over the color. usually shops charge more for pearls because it takes more steps to do these paint jobs
