1 - 15 of 15 Posts
OG SF Member #603
I picked up 1 of the cheapy 4" eBay fmic's for a project and, of course, it didn't come w/ the bolts and brackets to install :rolleyes: Does anyone know what bolt size and thread pitch fit the holes? Any install tips/tricks would be appreciated as well :)
Thanks.
feeding your habit
They are M8's, forget what thread pitch though.
Boost4fun
If I am not wrong and the thread is M8 then the pitch is usually 1.5mm..
I think these are as hard to get in the States as inch screws over here;)
Prepare yourselve for a tricky installation, especially on the driver side. There you need a 180° ellbow.. then a direct 90° upwards ellbow..
Gerd
OG SF Member #603
Thanks guys.
I don't like that 180 elbow comment though....I just bought a damn pipe kit and of course there's no freakin' 180's in it.
feeding your habit
90 + 90 = 180....
your local Home Depot or good hardware store has the fasteners, we use metric all the time here in the states, we're not snobs like the EU. ;)
OG SF Member #603
98mkiv said:
90 + 90 = 180....
QUOTE]
Yah, yah :rofl: I was just hoping to keep the cutting to a minimum.. This fmic must be wider than I thought.
Thanks again.
Boost4fun
98mkiv said:
90 + 90 = 180....
C´mon, we are no snobs here;) I mean I am even confused when it comes to wrench sizes like 12/16 and whatever...I know, it´s not a big deal when U R used to it but for beginners like me....sheesh.. :bowdown:
And obviously I was wrong with the pitch :rolleyes:
OG SF Member #603
Hmmmm.....thread title changed from "Ebay" to "Cheapbay" :wtflol: , I guess someone w/ some authority prefers it this way :bowdown:
Anyway, thanks for the answers guys :)
BTW, anyone have any suggestions for cutting stainless steel fmic pipes? Hacksaw, reciprocating saw, circular saw, etc?
Recovering Supraholic
Miter saw with the proper cutting wheel, is the cleanest cut . Be carefull since you might have to play with the saw's shroud. I did my own pipes last winter and almost lost a thumb (was not carefull) :ugh2: 6 stiches
feeding your habit
I used that cutoff wheel, and it's great but if you don't have it a reciprocating saw with a metal blade works 2nd best. cheap too.
OG SF Member #603
Discussion Starter · #12 ·
OK guys....I'm back w/ another question. I picked up the bolts, thanks. But now I need the brackets to mount the fmic. What are you using for this and where did you get it?
Thanks again.
Boost4fun
You can use some simple zinc plated steel brackets of home depot or similar. With my IC came four brackets 2 for the upper side with a 90° angle and on the lower side you can use simple straight brackets and screw it into already existing holes with threads
Gerd
feeding your habit
I used aluminum plate 1"w, 5"L, .250" thick. Used the OE holes on the upper frame and drilled into the lower rad support (careful you don't pierce the condenser :crossfingers: )
makes it harder to search
:rolleyes:
1 - 15 of 15 Posts
