jin-chuu said:why shouldnt i get the ones with rubber dampers? i heard the only difference is the shifting which the springs shift a little smoother.
http://www.autozone.com/servlet/UiBroker?UseCase=O001&UserAction=parseShoppingCart&Parameters=CLUTCH+DISC=870774=6998$_
^~~~that is the link for the N/A supra clutch disk, so that will work for the r154 tranny right?
1st of all:williamb82 said:..... obviously your stock if your buying a stock clutch. if you guys like spending more money just so you can say you have the brand name be my guest. i got my 4 puck clutch built locally for $130. cant see paying $500+ for a spec or like. the pp can be moded for more pressure if i ever need it for $170 so $300 for a no name clutch that hjolds the same as a $500+unit. why waste money? theres a diff between being cheap and just being smart on how you spend.
