1 - 2 of 2 Posts
i just installed my motor and on the harrness someone hacked it all up , so when i put it back in the wires pulled out , does anyone know the easyed wy it repin , well i have 3codes one icode is the 35 and i see the wire pulled out on that , the others are 47 wich i have no idea and the 78 is the fuel pump and i dont know what that would be , thanks for the advice josh
obd-I
78 Fuel Pump Control Signal
47 Sub-Throttle Position Sensor Signal
35 Barometric Pressure Sensor Circuit
i found this codes from mkiv.com
1 - 2 of 2 Posts
