1 - 4 of 4 Posts
I started the car up this morning- got the check engine light with the warning light, after 10 mins i shut the car off, turned it on again and both lights went away...this happened the same way the day before.....when the light was on my heat was not working either--- im assuming its a loose belt? im hearing no squeaks, but the belts are pretty new.
check belts for good tension
what code did it throw
Custom User Title
is this still happening? i see you are bpu. if you adjusted your fuel curve you could also be getting super rich A/F ratios when cold and it may throw the CEL for an emissions problem. i would check the code like the other guy mentioned.
1 - 4 of 4 Posts
