1 - 7 of 7 Posts
got boost???
ok so like i said....my check engine light came on for few seconds and shut off as i hit fuel i believe....car ran fine after that....ithe check engine light is not on but i decided to see if there was any codes...i pulled a code 11? if the check engine light is not on and doesn't stay on should i disregard it?
11 ECU(+B)
Diagnosis
Momentary interruption in power supply to ECU.
Trouble Area
Ignition switch circuit
Ignition switch
Main relay circuit
Main relay
ECU
got boost???
yea i kno its power source to ecu but im saying if the engine light isn't on but a code is stored? should i just erase it or is there a problem? only thing was hitting fuel and installing ebc
clear the codes and see if they come back. if they do come back check grounds.
also how did u install your ebc? where did u tap for power source?
got boost???
tapped it into a unused fuse hole (one that was just blocked off) on the driver side kick panel
i asked dr j while i was talking to him and this is what he said:
[00:12] int pwr
[00:12] justmeans @ some pt
[00:12] power wasn't constant
[00:12] i.e. if you tried to jump the car
[00:12] or were messing w/stuff
he later said clear the codes and see if it comes back and take it from there. hope that helped
got boost???
thanks jpeek....i think it was when i tried jumping the e1 n t1 terminals? well the check engine light doesn't stay on n car runs good so i don't think its throwing but i decided to check anywyas since i hit fuel cut
1 - 7 of 7 Posts
