1 - 4 of 4 Posts
SF lurker...
Hi I'm a new owner of my Supra and I'm trying to work all thi kinks out from the previous owner! The two main issues I'm having as of now is...
-my cig lighter isn't working (the outlet, not just the cig lighter) Ive checked the fuse and it's good and the connectors are hooked up to it...any advice?
-there are two plugs behind my a/c control panel that i can't figure out what they should go to! They are in the area behind the hazard switch/the clock. One is black and the other is white. I've looked all around the area and didn't see anything so I looking for some help!
Any advice is much apprieciated!
I8 YUR V8
for the cig lighter you can check to see if it's getting 12volts. If it is then you might have a bad cig lighter.
as for the two plugs... if they are ones that look like antennae plugs i just noticed 2 as well on my supra the other day. I followed them, 1 goes to the rear defroster and the other one was just laying in the hatch area (i'm assuming it was for the stock subwoofer that i don't have anymore) I believed my rear defroster worked even when that plug wasn't plugged in but i could be wrong. Maybe a few others will chime in... i'm kinda new at the scene but i'm learning quickly as well.
not the defroster but there's a antenna in the hatch as well.
if thats the plug you mean.
SF lurker...
the cig lighter problem was the fuseable link located on the back of the cig lighter socket. Thanks for the help!
1 - 4 of 4 Posts
