1 - 11 of 11 Posts
Republican
So, how do I do it? I am having the head milled, but what about the block? clean it with a razor? I'm just not sure. I have looked in the MHG thread, and thier is no mention of it. BTW I DIDN'T blow my HG before i took it off.
Can't touch this!
Is the block out?
If it is then I would have it machined as well!
If it isn't then take out the 2 pieces of doul that are on each end of the block. Take a razor and go over the block for quite a bit trying to get all the crap off. Then lap the block using a drywall sander and the different grits of paper. I can't remember which grits but I'll check that today for you.
Then it should look almost brand new!
I think that's it for now!
Later
Jason
I used a razor blade and cleaned up the block surface...should be OK as long as you don't score the block surface
Yeah....I used some solvent (paint thinner I think) and a razor blade and didnt have any problems. Is damn hard to scratch the iron block with a little razor so scoring shouldnt be an issue. Just make sure that where the MHG seals that you cant feel any bumps or ridges with your fingernail.
LEADED FUEL ONLY
Brake cleaner on a blue shop rowel will remove all surface contaminates. You may have to go thru and pick off all the blue fuzzies the shop towel will leave.
I used this after the block had been machined and lapped.
1 - 11 of 11 Posts
