1 - 15 of 15 Posts
Before I start, here are the turn signals I used:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7935316266&category=33717
I started with the clear lamps above. After taking the factory UGLY orange ones off, I knew I had a challenge ahead of me.
There are 3 big differences between the 93-96's and the 97-98's.
1) 3 bolts instead of 2. To tackle this, I will remove one of them and use 3M molding tape to secure the turn signal to the bumper cover. Although not needed, I used the tape to make sure of a perfect fit
The aftermarket bolt just screws out, so no cutting the factory bumper cover will be needed!
2) The 97-98's have the marker in the turn signal. I am going to eliminate this by making custom harness filler's, so no trash can get in the previous hole.
I made some cover's out of thin aluminum and polished it to match the chrome housing inside the lamp.
I cut them polyganol(sp?) so they could be pressed in firmly and then hot glued them to the housing to seal it.
Here is a pic of one finished vs. the unfinished one:
3) The 97-98's have a different turn signal harness pattern. I modified the aftermarket housing by cutting it out large enough to squeeze the 93-96 harness in and although it was secure I made sure it wasnt coming out by beading it with hot glue.
After purchasing a $40 set of clear lamps, a $1 glue gun, and a $5 roll of 3M tape(optional) you have a set of clear 97-98 lamps for <$50 with no cutting or modification to your factory bumper or wiring system.
If you have any questions about this, you can contact me thru PM or by e-mail. This is probably not as good a writeup as Brad would do, but it is my first one:D
Later,
Jason
just a question: what kind of bulbs did you use with the new lamps? I guess you did not use the stock ones because they're white, and without an orange lens in front of them they would flash white :D
I used the stock white bulbs although they came with the amber ones. The white actually shows up better than amber IMO. I dont think white front turn signals are illegal either, just the rears.
Jason
what was like the bulb that came with the turn signals? left one (stock supra bulb) or right one? I ask you cause i do not know of the existance of orange bulbs in the shape of the stock supra bulb!
link of pic, if it doesn't show up: http://digilander.libero.it/nicoimmagini/IMG_2236.JPG
Thanks 4 the info!
My car has the ones on the right as stock,but they are clear? I dont know what the ones on the left are?
Jason
the one on the left is the stock front turn signal bulb for 93-96 and 97-98 supras. The one pictured is actually taken from a 98 front signal bought from Curt! Maybe in the aftermarket you have they fitted the other one (afaik it's only in orange, though!)
personally, I like the look of the Supra 97+ turn signals with the 2/3 amber and 1/3 crystal look. The complete crystal look is a little ricey for me.
Discussion Starter · #10 ·
BUMP, I have been asked by another member for the writeup. All of my info was lost when my computer crashed last month. I sent this out to alot of people, and honestly I dont remember even one of them. If someone received this from me and they still have the writeup and pics, please either PM me or respond here.
Thanks,
Jason
Those are 7440's. Polarg makes them in amber.
Discussion Starter · #15 ·
ttt, I know somebody has this info.
Jason
1 - 15 of 15 Posts
