I had the same thing happen with my car when it got shot. Actually, my car was repainted red before I bought it, and I had it painted RSP. The previous red paint job wasn't done too well, and many of my seals had red on them that I needed to remove. I either used my finger or a razor blade to scrape off the base and/or clear. If you use a razor blade, be very careful or you may cut into the seal.
After you scrape it all off, the seals may look dry in the spots that were scraped. I used a plastic conditioner that moistened the plastic and got rid of the dry look. I don't remember the name of the stuff cause It was in an unmarked bottle at my friend's shop. If you go you napa or pep boys they should have something that should do the trick.
Like blkturbo! said, if you have it pretty badly you may be better off taping off the seals and spraying them. My friend who painted my car said this is often done to older cars instead of replacing the seals.
Good Luck,
Tony
