1 - 12 of 12 Posts
No Mercy
Hi,
There's a weird clicking sound that speeds up with my car coming from my front two wheels. It sounds like a combination click/stick sound (kind of like you're peeling a sticker from a surface over and over, rhythmically).
When I have the car up in the air and spin the wheels it doesn't happen, so it's really hard to diagnose.
I think it might be my wheel bearings, but there's no play in the wheel when I shake it. It might also be my tire just acting funny.
Any ideas or suggestions?
yah dood.. could be wheel bearings .. vertical pressure and spinning.... the only item really affected during that phase is the wheel bearing... good luck in finding the culprit!
clicking sound
Do you have stock wheels or after market. I found that one of my lugs came off and was making a weird noise after every rotation.
Actually, I've got an idea.
I installed slotted and drilled rotors on my front brakes, when I upgraded the calipers, but I don't use a brace plate to hold the pads back. I've noticed that there's a kind of sliding noise like something is dragging slightly on the surface, and when it goes over a slot, a kind of quiet thtuck sound. All this is at low speed, and pretty much dissapears about 40+KPH (25MPH).
Definately check the lugs are torqued, and check to make sure that the wheels aren't cracked. A buddy of mine had cracked wheels on his v-r4 and it sounded like that.
I had this same sound from my rear passenger wheel, turned out to be the wheel bearing. I put the car up on jack stands, had no play in the wheel, could never reproduce the sound by just turning the wheel. In fact, really the only time I noticed it was when I drove right next to a curb, and slowly. The faster I went I just couldn't hear it due to road noise, wind, etc.
No Mercy
Discussion Starter · #10 ·
Eugene,
Yup sounds exactly right.
Thanks for your help, how much trouble/money was it?
thanks.
1 - 12 of 12 Posts
