1 - 3 of 3 Posts
as long as it is a usdm supra they will plug and play the only thing ull see that doesn't work is the feet/defrost button cuz if u look on ur factory one that option inst even there i cant remember what it does when u select this feature but yes the swap will plug and play i just did it to my 86.5 i put a 89 climate control in it worked just fine
· Banned
As long as it is a USDM Supra, they are plug and play.The only thing you'll notice that doesn't work is the feet/defrost button. If u look on your original unit, that option ins't even there. I cant remember what it does when you select this feature. Yes, The swap will plug and play, I just did it to my 86.5. I put a 89 climate control in it and it worked just fine.
1 - 3 of 3 Posts
