1 - 15 of 15 Posts
Clock and A/C, heater, EVERYTHING stopped working..
The harness is plugged in the clock, the two orange harnesses are plugged in as they should be, but no response...they're like dead. :( I hope its fixable because damn i use the A/C frequently and i like to see the time a lot :dunno: this sucks......
check the fuse under the dash i think its the second row down third one in, on the cover its the cigg outlet fuse, same thing happend to mine, 15 watt fuse
the lighting for the piece of the dash works....all buttons dont work...a/c / heater knobs do not work, clock doesnt work... everything absolutely doenst work...
anyway i did a quick scan through the fuses (underneath the steering wheel; left side right?) and no clamps are blown....but it was a quick scan so i dont know. If the fuses isnt the problem then IM SCREWED, fuck how could it come to this.
Discussion Starter · #10 ·
hey hksguy your right, it was a blown blue 15 fuse....now why does it say cig only? would it fix the clock, a/c and all the other shit too?
High Performance WorkShop
Check ALL your fuses , including the ones in the engine bay , If all the fuses are fine and ur console is still disabled . let me know and i'll tell you what to check !
Discussion Starter · #12 ·
I really appreciate your help UAE Boost, but I found the blown fuse :) it was the cig blue (15) fuse, it has been replaced everythings perfect now.
Your Very Welcome Bro ^-^ , if ya need any help , electrical or mechanical , just let me know !!
Very Glad to hear u've solved the problem ^-^ .
Just curious UAE, what would you have recommended to look at next?
cherzra Just curious UAE, what would you have recommended to look at next?
as i've got a couple of HKS gauges and turbo timer installed , i had to hack into some wires that belonged to the cluster and dashboard and e-brake .
hks supplies you a red clip to join 2 wires .. these tend to break the wire and cut it loose .. i faced this problem 3 times now , it's always a ground wire that is cut loose from these stupid clips . ^-^
1 - 15 of 15 Posts
