When steering all the way to the left i hear a clunking sound. i cant find out where its coming from. new power steering pump, new rack and pinion new fluid.
Hopefully its your head being smashed in the wheel well......
Just sayin....
this here. check it out. even if you have no confidence in this, do it first since its the easiest.Its probably your steering stoppers being 20 years old or not there at all.
43212C in this pic
Look at your LCA I'll bet you have some fresh metal where the stopper hits
If your fully cranked and have some suspension travel then its will rub and clunk
moving, when still it doesnt do it.If you are sitting still and turn the wheel all the way will it make the clunk? Or does it only do it while you're moving?
