1 - 10 of 10 Posts
two wheels is all i need
Today i took off my transmission thinking the clutch burned out and all i had to do is just replace that!.... moments after i unscrew the last bolt that holds the transmission in place i found out that a Huge chunk of the flywheel was broken off. I was upset but thankfully i have another flywheel laying around. Few short seconds after that i took the pp off, and thats when something ive never seen struck my eyes... the pp was split in half. Ill post pics up as soon as i fix my SD card driver on my computor but i just wanted to ask if anyone experienced this before. The bellhousing suffered some damage as well. I dont know if its such a good idea to put it back on the engine. again ill have pics sometime tommorow hopefully.
Your ignorance...
holy fuck, what kind of power are you making, and who are you that drives harder than me to break a flywheel!?!? I broke many things, but never a flywheel... :1poke:
I had a friend with a mustang that did a huge burn out just before getting new tires and burned out his clutch in the process. When we pulled everything apart we found the pressure plate boken into 3 pieces! I almost shit a brick when i saw that.
blue_spra said:
did a huge burn out
The car is stock with no exhast, im in the process of getting a new one. single pc driveshaft and FPIK thats all i have for mods. This did happen when i was attempting to do a burn out, it was a nice day the car was behaving better than it ussually was i figured hey what tha heck whats the wrost thing that could happen, i need new tires anyway. Than this shit happened. Im very upset. The flywheel before hand was not resurfaced and was off an 89 N/A kind rusty it was when i put it on so maybe its seen better days. But the PP is brand new!(From AutoZone however so im not that surprised. 17$ for clutch and 35 i think for PP... plus the core charges.) Im not worried about the flywheel what i am worried about is that my bellhousing is cracked :( the damage doesent look to be too bad and it seems like i can use it w/o worries its just that this happened now right when the good weather hit. :(
Ill get pics up tommorow morning.
what would jesus drift?
is that a w58??
0 to gas station in 5 sec
Isn't the other flywheel already hosed? I thought the pins are sheered off it?
We need to get you a r154 setup.
Anyhow, good luck with the repairs, i'll be in the area this weekend. Actually, I'm gonna be at the newington junkyard today.
yeah this is a W58... and yes the pins on the other one are messed up but maybe i shop will put them back somehow.
here are the pics...
wow
ther eis a reason it cracked
evidence is on the pressure plate...discoloration = HIGH HEAT!!
1 - 10 of 10 Posts
