1 - 3 of 3 Posts
FasterThanASpeedingCivic
How do you tell when your clutch is going? Mine is starting to slip and Burn up at high RPM dumps. Mind you its all stock 7M-GTE.
Is it releativly easy to change out, any special tools needed?
You answered your own question (its starting to slip). If its slipping, lay off the high rpm dumps. Doesn't take long to burn up a disc once it starts going south.
Dr Wheelspin Rh.D.
Floor it in 4th gear will usually result in slippage if your clutch is going out.
No specialized tools required except a c-clip remover tool comes in handy. Hardest part is lowering and raising the 100lb transmission.
1 - 3 of 3 Posts
