1 - 10 of 10 Posts
1,150+ rwhp club
Should the plate and wave washer inside the 6 speed be free to move around? How do you know when they are installed correctly?
Here's the situation, I'm doing an auto -> 6 speed swap. The 6 speed is in the car now and everything is bolted together. If I reach my hand through the access panels and feel behind the pressure plate, there are 2 rings (not c-clamps) that are free. Where do they go? Do I need to drop the tranny again?
Here is a link to a diagram...
http://mkiv.com/manual/manualtt/clutch_replacement/c1.jpg
1,150+ rwhp club
JP IMPORTZ said:
Did you put the snap ring on top of the washer? If you did then you are fine.
JPI
I cna't feel a snap ring. Nothing is there holding the 2 washers on anything on the back of the pressure plate.
the weird thing is I pulled the tranny out of the donor car and never took the pressure plate out. I'm thinking it could have been that way on his?
96152-00500 snap ring list 2.66 cost 1.97
90560-50001 snap ring
90560-79001 spacer list 2.31 cost 1.71
90206-12006 wave washer list 1.57 cost 1.17
90520-75001 snap ring list 2.97 cost 2.20
31264-14060 spring list 2.97 cost 2.23
31231-14050 hub list 33.38 cost 24.69
All of the above are needed for the hub.
1 - 10 of 10 Posts
