I just installed my factory clutch disk with the RPS blue pressure plate, and my car wont go into gear when running. I dont think its the pedal adjustment as the slave cylinder is getting good travel. I initally thought the stock disk was in backwards however after tearing everything back down it appears the stock disk can only go in one way or else the pressure plate bolts wont reach the flywheel, I have the longer tapered center section of the clutch facing the flywheel. Is there something stupid I could have done wrong here?
