Since I cant search I need someone to remind me if they could about which way to spin the rod or nut to raise the clutch disengadgement point. I am having problems getting it to totally disengadge and cant remember what to spin or which way after I loosen the first lock nut on the shaft. If anyone knows please let me know.
you mean turn it clockwise? ALso am I turning the rod or is there a second nut behind the lock nut? Very quick response to forgot how good this forum can be
if looking at it passenger side being clock wise and towards drivers door being counter clockwise?? Is there a second nut that gets turned or is it the rod itself?
If this doesnt get answered ill com back and answer it so it can shortly be lost and never used by other again. I cant believe how long the search has been out for
You want to loosen the jamb nut, and then turn the shaft so that it threads out of the pedal so that the shaft becomes slightly longer. This will allow for more clutch movement.
OK here it is loosen the nut there is only one. Then turn shaft towards passenger side (or clock-wise) to raise the engaugement point. Hope this helps someone else.
My shaft could not be turned easily b/c it was all the way at the bottom and jammed tight once I broke it loose the rod could be turned by hand.
