1 - 2 of 2 Posts
I have a 97 6 speed. The cluctch pedal assembly is moving all around. really loose. when i looked at it under the dash there are 3 bolts that mount the pedal assembly. 2 go into the firewall and one goes straight up under the dash. all bolts are tight but it appears that what ever the top bolt is bolted to the whole bracket is broken. I can move the clutch pedal bracket and the upper bolt is moving freely even though it is tight. It appears that what ever bracket that upper bolt is bolted has ripped appart. The upper bolt is basically not holding anything so the whole pedal assembly is wobling all over the place.
My question I guess is what exactly is that upper bolt bolted to. Is it something that I can replace or fix and how would I go aboult doing this. I cant really see with out removing the entire dash so any help before I remove thr dash would be great.
1 - 2 of 2 Posts
