1 - 7 of 7 Posts
Addicted to Boost
ok the other day i was driving around, and my clutch pedal started to stick as soon as i let off the clutch and then it would come back up on its own before i engaged again for the next shift. so the CMC is basically only a few months old. i readjusted the pedal , now it has no problem..plenty of feel and stiff as a rock(TRD racing clutch).my only question is could my master be going out again or could the slave be acting up? car will possibly be onthe track , so thats why im asking...thanks
jason
bleeding it would be the best idea and if not make sure nothing is stuck behind your pedal.
~steven
Sir Digby Chicken Ceasar
It's not for sure the slave but much more likely if you replaced the master recently. Bleed first if that doesn't fix it the, replace the slave, bleed again and if not do the master. Check for leaks also and see if you're loosing any fluid.
slowly giving up...
yeah, mine just started sticking. i'm going all out and replacing the master, softline, and slave cylander. :) doin' it all in one shot.
-shaeff
1 - 7 of 7 Posts
