i have a rps stage 3 with a stock oem flywheel. never had any chattering issues with this clutch till i came back from the track. it would chatter pretty bad at idle. step on the clutch and the noise is gone. it this the flywheel? throw out bearing? any comments appriciated
Tom Henderson
i got that same clutch but with the lightened flywheel and it chatters a bit at idle...and since you have the oem check out the throw out bearing..did u change the bearing when you installed the new clutch???
