1 - 2 of 2 Posts
I've been searching for hours, and haven't found anything on this so hopefully someone can help.
I have the RPS stage 3 along with their alum. flywheel. It probably has about 3000 miles on it now. I was out playing with the car with everything working fine. Then after a hard launch I push in the clutch pedal and it wont go into gear. Turns out that it seems like the clutch won't engage. I can shift fine with the engine off and I can start and drive the car in any gear, but can't shift or stop. I pulled the clutch fork cover while having someone press the pedal and I can see the fork pressing the fingers in, however I don't know how far they should normally move.
Anyone know? Any other suggestions?
General Hooligan
sounds more like ur clutch is not disengaging, try to bleed the system and if that doesnt work id be checking ur slave and/or master cyl's for leaks wetness around the plunger on the master and around the piston on the slave, pull back the bootie ont he slave and see if theres any fluid accumulating in there, that should tell u
1 - 2 of 2 Posts
