1 - 11 of 11 Posts
I have noticed that when I get out my car with it running, the clutch makes a rattling sound and if I press in the clutch it quits. It has the rps twin disk, is this normal? Thanks for any comments on this.
A zone of danger.
Yeah, its normal. I've got a twin disc too along with a LWFW, which I'm sure the RPS has as well. Its a little annoying, but you'll get used to it.
Supra Owner Since 1996
Yes it it normal. If you run an AEM you can set your idle at about 1100rpm or to the point where the sound is gone.
cinnamon jelly bean
Yep, thats your tranny making the noise which is perfectly normal. You dont really notice it with a stock flywheel since the factory one is dampening and it absorbs the vibrations keeping it from rattling.
I have the RPS max PP with stock disk and stock flywheel and I still get a very small amount of noise when im in nuetral but when I press the clutch it goes away.
I have the same issue and I've got a stock clutch and flywheel. I can hear it make its last shudder when I shut my car off. It started making a loud shudder/whine the last time iwas at the 1/4 mile track. It would not immediately go away unless pressed down on the clutch or let it cool down.
Can someone explain why i can hear and feel it after normal drives? warped clutch? it doesnt seem to slip.
1 - 11 of 11 Posts
