When in nuetral and emergency brake engaged. The clutch will often engage and the car will move forward an inch or so. Also while in reverse sometimes backing up the car i have to give it more gas than normal. For example my drive way has a small decline if i'm backing out and press in the clutch the car will sometime stop. Normally it will continue to roll out into the street as it should. Any ideas as to what would cause this? I figure a warped flywheel could cause it in nuetral, just not sure about reverse.
Sed
Sed
