1 - 2 of 2 Posts
hey guys i just installed my new SPEC stage 5 clutch with a Fidanza Flywheel and i know i put everything together replaced all bearing and everything that needed to be replaced. Well when i went to crank the car it crank fine and went into gear and everything good. But when i put it in neutral the wheels would still roll and when i pressed the brake the clutch would rub really badly. I dont get it i bleed the lines and checked the play in the clutch but everything was good. So please give me some advice maybe i need to bleed the lines more or maybe i wasnt bleeding the clutch right. Please give me some insight and how you are suppose to bleed the clutch or if you think it is something else. Thanks
1 - 2 of 2 Posts
