1 - 3 of 3 Posts
What it is Jive Turkey?
I did a diagnostic and I pulled up a few codes. 14 and 52. I'm not too worried about the code 52 as it's a knock sensor.
Code 14 is the ignition signal.
Ignition and ignition coil circuit
Ignitor and ignition coil
ECU
That would explain why it sputters and backfires sometimes under WOT. I've replaced the spark plugs (gapped to .32) and put in new wires. The coilpack is grounded and all the connections are tight. Any way I can check the ignitor and coil to see which one it is?
TheFastCoonAss
Fix the knock sensor.
Check the Coil Pack per the TSRM, or if you have another to swap, try that.
Same thing with the ignitor.
My buddy Lewis had Code 14, turned out he tried my ignitor on it and sure enough that fixed it.
1 - 3 of 3 Posts
