Hello everyone,
I'm keeping on with my 89 Turbo M/T that I pulled out of a yard for $500. After replacing both sensors to fix code 52 (shoutout to my dad's cousin who has a lift in his garage, that rear sensor was a bitch) code 52 came back next drive. I'm assuming it's wiring at this point. I'm planning on rewiring, but is it worth it to go all the way back to the engine harness with new wiring? I want to avoid having new wire spliced onto old wire, you know? If so, I'm thinking about pulling the harness and refreshing it a bit while I'm there. I'd like to label things, put new loom on the bundle coming across the firewall, stuff like that.
Does what I'm saying make any sense? Has anyone else done a pull-and-refresh on their existing harness? If YotaConnectors wasn't essentially defunct at this point, I'd consider getting the guy to refresh my harness. Also, as for the knock sensor, will I run into trouble if I go with coax wire like other people have if I'm running it back to the harness? Do I need to splice down to something smaller anyway?
Thanks.
Edit: I think I've done enough reading to be able to wire the knock sensor wire all the way to the ECU. I'm going to try to place a new pin to the ECU on the new wire for both. Is there a size or something I should be looking up for ECU harness pin?
Thanks.
