1 - 10 of 10 Posts
Are the plug ins that connect to the coil packs still available? I changed my spark plugs and kinda broke some tabs on two of them. Let me know, thanx!
So what am i getting for 4.08? Is it just the complete clip, does it come with a little length of wire, and how would i go about ordering these from you?
Team 10+ Year Member
Curt I may be an idiot, but I broke mine too and am away from my car at the moment (or I would look for myself) but how do you go about changing the clip?
I have to look at it, I guess that was an easy question.. thanks Curt. I am just trying to figure out what parts I need and I should be ordering a bunch of random things from you in the next week or so. If I change the vavle cover gaskets do you suggest replacing the bolts as well at that time, and washers?
Turbo Member
Curt Aigner said:
Remove black connector from coil pack.
Remove white center clip.
Remove the two wires from the connector, don't mix them up!
Install reverse order.
Mine fell out when messing around with the plugs. Then I tryed to fix it and got the two wiers mixed up. How do I test them to figure out the proper order?
1 - 10 of 10 Posts
