1 - 8 of 8 Posts
testing coil pack now any quick advice is helpful********
@ high rpm my car hesitates!!!!!!
I suspected a boost leak but found none,
I then checked over my spark plug wires with my timing light to see if the wires were getting power
I found that the timing light would not flash on both of the wires comming off the middle coil pack but was very functional on the remaining wires
when I removed the boot off the spark plug while the car was on it sparked then
my question is
Do the coil packs weaken or just fail?
if you take your timing light and put the sensor on any of the wires and pull the trigger the light on the gun will flash to that cylinder i did that because i suspected somethinf wrong with a coil pack
7m power
theres a reason its called a timing light and not a spark plug wire tester,if i was you ill check that the timing is correct and also your spark plugs
89 Turbo
Don’t worry, I check the same way you do, all it does is check for current in the wire.
That’s all you need,
But if I where you I would check the wires going to the coil pack, from the igniter. Make sure everything is all snug and if that all checks out check it with a volt meter.
I believe coil packs usually don’t just go bad; but you never know…
check it with ohm meter.
Reason is that at the voltages being produced by the coils, it will jump a gap easily but it will show an open on the ohm meter. That is why testing with timing light is pointless.
1 - 8 of 8 Posts
