Hey Curt, i tried searching and ended up confused and uninformed.
I replaced my sparkplugs last week, and cyl#1 coilpack connector disintegrated and exploded when i took it off.
on top of that i got really mad because 4 other connectors were not only broken, but someone epoxied the female ends into the male ends.
I dont think i can salvage the coilpacks and replace only the connectors.... epoxy everywhere :furious:
Also, one of my spark plug's was what I would call 'not torqued down enough' which explained my issue about revving up from idle. there was some exhaust blow-by which split one of my plug boots.
can you quote me on 6 coilpacks (or is there 3? whatever i want to replace all 6 cyl), 12? coilpack connectors, 6 sparkplug boots, and any other required parts i should replace at the same time?
for 93 mkiv tt. its rhd aswell but these parts should be identical.
thx. i'll be putting the order through asap.
thx to that #1-cyl coilpack connector being jimmy rigged on atm, my car is sporadically misfiring at random times at high rpm. so i need to get this back up to my high standards.
