1 - 3 of 3 Posts
Purchased and installed the Garage Whifbiz kit ( Garage Whifbitz 2JZ-GTE & 1JZ-GTE R35 GTR Custom Coil Pack Kit ) but any GTR coil pack kit and adapter plate will work, this one just includes the coils, screws, and wiring harness.
The wires do need to be soldered correctly if you use the included harness but the coil packs are wired directly into the AEM ECU and bypasses the stock igniter.
250943
250944
250945
Super Moderator
Good info to share - but an AEM V1 is fairly primitive and with few exceptions such as the IS300 wastespark coils, the AEM V1 generally needs an ignition amp to help any direct fire coil setup actually keep up with the RPM demand, even with coils like IGN1A's and R35's.
1 - 3 of 3 Posts
