What ports do you use for the colant lines to the turbo??? I'm useing one of the on's on the colant neck but I'm not sure where to run the other line let me know if you can help
i capped off the lines on the waterneck, and the small line on the hard line that goes behind the head, and used the big coolant line from the same hard line as feed, and the waterline that goes down by the alternator for return.
