Status
Not open for further replies.
1 - 19 of 19 Posts
Anime Dork
Just getting a list together to make things easier on everyone of commonly requested part numbers. I will be adding to this list little by little when i have time to work on it.
PRICES ARE SUBJECT TO CHANGE
Headlights
97-98
81111-1B241 UNIT ASSY https://parts.elmhursttoyota.com/oem-parts/toyota-composite-headlamp-811111b241
81151-1B241 UNIT ASSY https://parts.elmhursttoyota.com/oem-parts/toyota-composite-headlamp-811511b241
94-96 Euro Glass (NEW PRICING AS OF 7/5/2016)
81170-1B220 UNIT ASSY https://parts.elmhursttoyota.com/oem-parts/toyota-unit-assembly-head-lmp-811701b220
81130-1B220 UNIT ASSY https://parts.elmhursttoyota.com/oem-parts/toyota-unit-assembly-head-lmp-811301b220
Tail Lights
97-98
81551-14700 LENS & BO https://parts.elmhursttoyota.com/oem-parts/toyota-lens-8155114700
81561-14700 LENS & BO https://parts.elmhursttoyota.com/oem-parts/toyota-lens-8156114700
Turn Signals
97-98
81510-80086 LAMP ASSY https://parts.elmhursttoyota.com/oem-parts/toyota-signal-lamp-8151080086
81520-80086 LAMP ASSY https://parts.elmhursttoyota.com/oem-parts/toyota-signal-lamp-8152080086
Carpet (Black)
58510-1B171-C0 CARPET AS https://parts.elmhursttoyota.com/oem-parts/toyota-carpet-assembly-floor-585101b171c0
TRD Sway Bars
PTR02-14930-03 BAR SWAY ORDER OVER THE PHONE. THIS PART IS MORE EXPENSIVE ON THE WEBSITE.
94-98 Turbo Engine Gasket set
04111-46094 GASKET KI https://parts.elmhursttoyota.com/oem-parts/toyota-overhaul-gasket-set-0411146094
94-98 Turbo Head Gasket set
04112-46094 GASKET KI https://parts.elmhursttoyota.com/oem-parts/toyota-valve-grind-gasket-kit-0411246094
11115-46052 GASKET, C https://parts.elmhursttoyota.com/oem-parts/toyota-gasket-cylinder-hea-1111546052
94-98 Valve Cover gaskets Turbo
11213-46020 GASKET, C https://parts.elmhursttoyota.com/oem-parts/toyota-valve-cover-gasket-1121346020
11214-46011 GASKET, C https://parts.elmhursttoyota.com/oem-parts/toyota-valve-cover-gasket-1121446011
94-98 Valve Cover bolts and washers x12
90105-06166 BOLT, WAS https://parts.elmhursttoyota.com/oem-parts/toyota-bolt-washer-based-h-9010506166
90210-07001 WASHER, S https://parts.elmhursttoyota.com/oem-parts/toyota-washer-seal-9021007001
94-98 Turbo Timing Belt Cover
11304-46050 COVER SUB https://parts.elmhursttoyota.com/oem-parts/toyota-timing-cover-1130446050
94-98 Turbo Cam Seals
90311-40020 SEAL, TYP https://parts.elmhursttoyota.com/oem-parts/toyota-camshaft-seal-9031140020
Dash Panel Screws
93568-55016 screw, ta https://parts.elmhursttoyota.com/oem-parts/toyota-glove-box-assembly-screw-9356855016
Radio Dash Panel
55405-14140 PANEL SUB https://parts.elmhursttoyota.com/oem-parts/toyota-cluster-trim-5540514140
Front Pads and Rotors TT
04465-14390 PAD KIT, https://parts.elmhursttoyota.com/oem-parts/toyota-pad-kit-front-disc-bra-0446514390
43512-14200 DISC, FR https://parts.elmhursttoyota.com/oem-parts/toyota-rotor-4351214200
43516-14030 DISC, FR https://parts.elmhursttoyota.com/oem-parts/toyota-rotor-4351614030
Rear Pads and Rotors TT
04466-14040 PAD KIT,D https://parts.elmhursttoyota.com/oem-parts/toyota-rear-pads-0446614040
42431-14150 DISC, RR https://parts.elmhursttoyota.com/oem-parts/toyota-genuine-toyota-1993-1998-supra-tt-turbo-rear-brake-rotor-4243114150
Radio Panel Button inserts
55537-14030 COVER, HE DISCONTINUED
55538-14020 COVER, TR https://parts.elmhursttoyota.com/oem-parts/toyota-cover-traction-control-5553814020
TRD Strut Bar
PTR04-14930-07 brace str https://parts.elmhursttoyota.com/oem-parts/toyota-supra-brace-strut-tower-ptr041493007
Anime Dork
Discussion Starter #2 (Edited)
Climate Control Buttons
55905-14200 KNOB SUB-
55905-14210 KNOB SUB-
55905-14220 KNOB SUB-
55905-14230 KNOB SUB-
55905-14240 KNOB SUB-
55905-14250 KNOB SUB-
55905-14260 KNOB SUB-
55905-14270 KNOB SUB-
55905-14280 KNOB SUB-
55905-14290 KNOB SUB-
55905-14300 KNOB SUB-
55905-14310 KNOB SUB-
MOTOR MOUNTS FRONT
93-95
12360-46070 INSULATOR
97-98
12360-46111 INSULATOR
Anime Dork
Mkiv Plug Connectors
90980-11400 Starter
90980-11349 Alt
90980-11246 Coil
90980-10532 Oil Level
90980-10926 ign switch
90980-10711 Tps
90980-10896 Efi Resistor Male
90980-10897 Efi Resistor Female
90980-10845 turbo boost sensor
90980-10947 Crank Sensor 2 Pin
90980-10947 Cam Sensor 2 Pin
90980-11062 Efi Temp 2 Pin
90980-11077 Fuel Pump Harness 5 Pin
90980-11151 Ignitor 12 Pin
90980-11152 Ignitor 4 Pin
90980-11166 Knock Sensor
90980-11362 Fuel Pump Ecu
90980-11428 Dash Temp 1 Pin
90980-11154 Stock Injector 550's
90980-10789 clock
90980-11028 main o2 harness side
90980-11027 main 02 sensor side
90980-11363 oil switch pressure
90980-10799 active spoiler
90980-10933 seat heater
90980-10957 trac 93.5-96
90980-11535 trac 97-8
90980-10801 headlamp level
90980-10801 lh pw switch
90980-10789 rh pw switch
90980-11236 aux fan 93.5-98 [motor side]
90980-11237 aux fan 93.5-98 [ harness side ]
90980-11143 speed sensor on trans
90980-11051 V160 reverse switch
90980-11077 fp hanger
90980-11080 fuel pump +/- under hanger
90980-11079 tank sending unit
90980-10943 a/c h/p switch
90980-11622 3 pin harness side 97-98 turn/park rh side
90980-11078 5 pin connector on FP hanger
90980-11144 iac motor
90980-10942 ac plug 4 pin
90980-11555 orange foot well 38 pin
90980-11562 white footwell 16 pin
90980-11469 gray footwell 20 pin
90980-11413 fuse box upper
90980-10897 fuse box lower
90980-11025 iat
90980-10841 map
90980-11156 evap vsv
90980-11195 diagnostics 23 pin
90980-11144 trac motor
90980-11156 egbv vsv
90980-11149 iac vsv
90980-11149 egc vsv
90980-11156 wastegate vsv
90980-10843 ign condensor
90980-11002 2 pin rack plug on rack
90980-11003 2 pin rack plug on harness
90980-11450 lh dash warning indicator
90980-10957 93.5-97 cruise swith @ squib
90980-11964 tundra 4 pin alt plug
90980-11148 2 pin glove box light
90980-11317 maf/ af mete
90980-11237 a/c fan motor
90980 -11235 temp sensor in radiator
90980-11245 3 pin harness side for 93.5-96 fog light cap
90980-11162 vvti valve 2 pin
90980-10957 93.5-97 cruise switch
90980-11214 ecu plug 80 pin
90980-11215 ecu plug 40 pin
90980-10946 female active spoiler 5 pin [ 2 large 3 small]
90980-10947 male active spoiler 5 pin [ 2 large 3 small ]
90980-11497 odometer
90980-11207 B/master level switch
90980-10825 seat belt buckle
90980-11075 2 pin fog light cap 97-98
90980-11150 NA dist plug
90980-10825 ash tray light male
90980-10824 ash tray light female
90980-11885 1zz coil connector .
90980-11497 ctr a/c amp
http://www.97supraturbo.com/1997 S...s Repair.pdf
post # 69 fyi
http://www.supraforums.com/forum/sho...6#post11871986
Anime Dork
Discussion Starter #5 (Edited)
MOULDINGS AND WEATHERSTRIPS
53395-14010 seal, hoo
53381-14130 seal, hoo
53383-14120 seal, hoo
67861-14310 weatherst
67862-14310 weatherst
62311-14070 weatherst
62312-14070 weatherst
63251-14050 weatherst
63252-14020 weatherst
62383-14030 weatherst
62384-14030 weatherst
67881-14130 weatherst
62381-14140 weatherst (hardtop)
62382-14150 weatherst (hardtop)
75533-14190 moulding,
55708-14030 louver su
75573-14210 moulding,
75720-14250 moulding
75710-14250 moulding
75551-14160 moulding,
75552-14160 moulding,
75552-14150 moulding, (hardtop)
75551-14150 moulding, (hardtop)
Anime Dork
97-98 TURN SIGNAL HARNESS STUFF.
81515-14390 cord, fr
81735-17070 cord, sid
82983-33010 wire, fr
90075-60001 socket pl
90075-99080 socket pl
Anime Dork
Discussion Starter #8 (Edited)
NA Engine Gasket Set
04111-46045 GASKET KI
NA Head Gasket Set
04112-46045 GASKET KI
Anime Dork
Discussion Starter #16
I'm going to be updating this section with links to the website so you can just order directly and find the prices.
1 - 19 of 19 Posts
Status
