1 - 15 of 15 Posts
94 TT compression numbers. Feedback from anyone?
cyl. #1 175
cyl. #2 170
cyl. #3 170
cyl. #4 170
cyl. #5 170
cyl. #6 175
Stock plugs looked a little worn, little carbon not much. I plan on switching to a step colder plug because of BPU+ upgrades.
Shawn Davis
airpowr said:
Grab on to something 193K miles :wtflol:
No suprise on my end. These engines are great and when they're well cared for they last a long time. I had just over 200k before someone rearended me and my compression numbers looked like a new engine and leakdown was still pretty good.
Not to hijack the thread, but I've been searching and was wanting to learn a little bit about compression numbers. MKIV.com says 156+ and all cylinders within 14 psi. Is there a number that's too high? For instance, the most I've seen posted on SF is 180 psi. Is it the higher you go the better, or is there a point where it is too much? There's also a guy selling a 94 with numbers varying from 150-157. Are numbers less than 156 going to be a big problem? Would this be indicative of needing a new head gasket? Thanks for any info you can provide.
Chris
1 - 15 of 15 Posts
