Hey guys im just curious to get a ballpark figure on something. I'd use the search but ...you know what i mean...lol
First question though, how much can you rev crower springs and tit retainers to?
Next, how thick is a stock gasket?
Also how big of a lift can you go on a GTE before the motor becomes an interference motor? I remember some saying you can still be fine on 272's.
Now if you have a head with 1mm OS valves and took 5thou off.
Using 20over pistons stock comp 8.5:1 and 272 cams with a 10mm lift.
What would the final compression of the motor be roughly? Not sure if there is a formula or something you can use.
Would it be intereference?
Thanks Ryan
Thanks Ryan
